We went with a different installer a few years ago when adding a few
more panels and a Sonnen backup unit. Only reason was the $1000
difference between the original installer's quote and a second company.
Have had no problems from this arrangement. I call the whichever
installer did the work on a problem part. In fact, I believe that
Enphase microinverter failures, which were covered by the Enphase
warranty, may have had one company replacing the inverters on panels
installed by both.
-- Rick Gregory
Salt Lake City, UT
rickg916@gmail.com
Sent: 6/9/2025 1:48:00 PM
Subject: RE: Adding storage after panels are installed
There are many variables but typically storage can be added, FranklinWH has a nice AC coupled solution, and it can be from another company. But I would need to know more about your install before one can give a definitive answer. For example if you have a SolarEdge system it may be easier to add a SolarEdge battery.
David Hrivnak
SalesEngineering
EcoLogical part time
