Hi Paul,
Not sure where you are located. I'm guessing somewhere between Yuma and El Paso. While most arrays are essentially self-cleaning from rain and snow, I have observed some arrays located near dirt roads or gravel pits that do collect excessive soiling. These will need periodic washing off with water and possible some physical action with a broom or brush once the modules have been wetted down, followed by a final rinse.
Since modules are manufactured to the IEC 61270 spec, there should be no arcing if you were to spray them with water but I have seen some modules made with what turned out to be lesser quality edge seal and back sheets that have degraded over time and fail the wet leakage test. Even when failing this test, there is a safe current path to ground so long as the system was properly installed during grounding. If your system has ever tripped offline during or shortly after a rain storm, I would have an installer come out to inspect for degrading back sheets or improper grounding. Otherwise it should be safe to spray some water up there. You can shop online for a brush on a long extension pole to avoid the hassle and risk of getting on your roof unless yours is a flat, T&G roof is is common in the desert southwest.
The only thing I would advise against is using a pressure washer. Garden hose should be fine though.
-Rich
Rich Stromberg
ESS Prog Dir / PhD Student
Equitable Solar Solutions / Univ of Alaska Fairbanks
Chair, PV Technical Division at ASES
Colorado
