That makes a bit of sense, but if you go with a micro you could continue to use your existing panels and just add new ones to add the capacity you have.
My sun power panels have degraded a bit but not that much.
I recently had a reroof done and my local insulation t crew took the system down and reinstalled it for less than $2k.
I have taken panels down before for other reasons and donated them to local non-profits, an elderly community center and a home for pregnant teens both appreciate the old but working equipment.
I'm considering a battery as we don't get much incentive to export power. Usually .02 kWh or so if we are lucky. The contracts that net meter are .04-.05 higher on all consumption and our transmission charges are 45% of our monthly, and are going to be increased next year.
I still think I'd be better off investing in a west facing array to fill out my production/ consumption pattern better.
David
So walk on air against your better judgement
Sent: 7/5/2025 4:59:00 PM
Subject: RE: comparing Enphase microinverter with Solar Edge string inverter with battery
Hi David
The reason I am retiring my 18 y/o system is because of a convergence of 4 things: I want to replace my 20 year old roof before it leaks; I have to remove the old modules to replace the roof; with new modules and power optimizers, I will be able to install almost 4 times more power on the roof by taking advantage of partially shaded areas and more efficient modules; and the 30% tax incentive will start to decrease next year. So put them all together and it makes sense to do it now. The old system has degraded very much as expected, about 0.5% per year so it is still making about 90% of the original power.
Thanks for sharing about your experience with Chiilcon microinverters. Never heard of them.
Steve
Steven Hegedus
Professor and Senior Scientist
University of Delaware
Newark Delaware
Sent: 07-03-2025 09:23 AM
Subject: comparing Enphase microinverter with Solar Edge string inverter with battery
I had 6kw installed on my roof in Minneapolis in 2016, and our bluetooth monitoring showed it would generate just shy of 6.2kw.... 9 years later, it's still cranking out 5.5kw regularly under full sun at solar noon, though it may spike at a bit under 6kw... I think a smidge of that lower output of late is due to the increase in wildfire smoke filtering from Canada or out west...
Luther Krueger, Curator - Big Blue Sun Museum of Solar Cooking
