The only inverter that I know of that meets that description is the Enphase IQ-8 MICROINVERTER. Since its a "micro" it requires one under each panel - and it's not "backwards compatible" with anything else....
If the sun shines and the power is down, it will provide as much power as you have solar (minus losses, of course...) but if you exceed what the sun and the microinverters are doing, it will SHUT DOWN, until you reduce the load to what the system is capable of...
Joe Utasi
PV Solar Consultant
Cinci Home Solar, Keowee Home Solar, DIY Solar Helper
