My home may be an anomaly as I designed it as passive solar. So compared to a typical house we get more winter solar gain and a lot less gain in the summer. Three of the last 4 years my PV array has produced more power than the house AND cars have used making us a net exporter of power. https://www.amazon.com/Driving-Net-Stories-Carbon-Future/dp/0692143831
Sent: 01-08-2025 02:35 PM
Subject: Jimmy Carter's environmental legacy set the foundation for today's climate action
David,
You are still using nameplate efficiency, which studies have shown to be optimistic.
Not sure exactly where you are, but this link (https://www.appalachianpower.com/savings/home/temperature/temperature-monthly-history?station=TRI&stationname=Bristol%20TN&year=2024) shows that Bristol, TN had 3488 heating degree F days and 1343 cooling degree F days for 2024. It will be a long time (hopefully) before summer cooling exceeds winter heating.
How renewable is your local grid? Do you use a timer so that you are heating water only with your own onsite PV?
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 01-08-2025 12:06 PM
Thanks Keith, unfortunately the link does not seem to work for me. That said if you compare the energy labels on the Rheem HP water heater today I see a 1/3 cost of usage so call it a COP of 3. I also have thermal, prewater heater that in 25 years, I have had to replace the tanks twice, and the glass plating once. Part of it may be sub par do-it yourself, but so far the costs have been much higher than my HP water heater. Inverters today are better than 95% efficiency so when combined with 21% efficient panels I can see 20%, but in many cases, who cares as there is often plenty of roof space. But given the COP of 3 that is 60% overall. My thermal preheater, is about the size of two panels and weighs some 700 lbs. Two solar panels weigh in at 85 lbs. So easy to add a third or a 4th if needed if I need more than "60%" efficiency i currently enjoy. Then I found there are some side benefits as well. Now in NE TN summer heating is now greater than winter heating loads. So the HP water heater helps with summer cooling, and it does some dehumidification. And it replaced a gas water heater so I was able to plug the 3" vent hole in the roof, saving some heat losses in the winter. Note I have had thermal hot water and passive solar homes for 39 years now. PV for 11.5 years. So I am not a newbe. I am an engineer who has been doing this all my professional life. Yes thermal has a place. But I fully believe PV is better in most use cases.
David Hrivnak
SalesEngineering
EcoLogical part time
Sent: 01-07-2025 09:32 PM
Good job keeping it short! I will try to do the same.
To compare to 50% system efficiency for ST, we need system efficiency for PV. With panel efficiency of 20-24% and balance-of-system efficiency of 80%, that is 16-19%, so higher than my original estimate, but still lower than for ST.
David,
The link I provided describes real-world measurements of HPWH efficiency, which are lower than nameplate efficiency.
This link (https://doi.org/10.1002/pip.2744) summarizes 110,000 measurements of age degradation, and finds 0.6 - 1% per year across several PV technologies. They also note large differences in measured versus nameplate degradation rates.
Capitalism and marketing at work.
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 01-07-2025 04:48 PM
To keep this short which I will fail at, you mention in ST allot of issues but gloss over the frequencies and related problems that they create. Fluid leaks are not just fluid leaks from pipes, so fix pipe. The damage that CAN result from said leak can be extensive. Pumps can last decades, but I have had then fail in 5. For me ST collector efficiency as a comparison to PV efficiency is a non brainer. However your PV efficiencies are under rated. Should be at least 18% to 20% today, depending on all downstream equip.. Drain back has its own problems and efficiency loss due to an extra XCHANGR and another storage tank usually on top. I personally prefer for less O&M and freeze safety, glycol and external SS flat plate exchangers, like used for Beer coolers, resulting in twin pumps. COP for ST are obscene in a good direction.
If you have SDHW, heat pump water heaters and de-superheaters for geo, make no sense. PV still makes sense for all non heating loads, which if you have EV's will far exceed heating and cooling requirements. My biggest loads are non thermal at this point (3 EV's) and allot of computers.
Embedded carbon for me is kind of a non issue for systems that have long time frame use. Housing lasting for 50-100 years, or more in special cases, cars at 100,000 miles plus, etc.. Short term (Plastics single use, very important) are a disgrace on embedded C. Etc.
Hay! I kept it short...
Sent: 01-07-2025 03:00 PM
Agree about generalities. It is a part of trying to make points in paragraphs, rather than writing a book.
Let's compare a specific example - PV and thermal water heating. The solar thermal system has one active moving part, the pump, and possibly a passive moving part, the backflow preventer. The pump and controller require relatively little electricity. Solar efficiency can be 50% or more, while electrical COP is 100 or more. Flat plate solar collectors with black chrome actually increase in efficiency over the first few years as the black chrome ages. The low-power pump tends to last for decades. If you are using a pressurized glycol system, then the glycol and expansion tank will need to be replaced periodically, but a drain-back system eliminates this. Energy storage is inherent and a 200 gallon tank is often used. In my experience, the most common cause of leaks in solar thermal systems is failure to accommodate thermal expansion. This can happen within a multi-panel array and in the supply and return piping. Take care to design for thermal expansion and leaks are unlikely. Collector slope can be designed to provide relatively constant gains throughout the year, so unless the house is unoccupied often, leftover energy is not a significant issue. There is embodied carbon in the components, but low operational carbon.
PV has low solar efficiency, 10-15% initially, with output decreasing around 1% per year. For this reason, heat pump water heaters (HPWHs) are often used to boost efficiency. Installation in a heated space in a heating-dominated climate means that the HPWH is drawing heat from the space. The average COP of HPWHs is 1.8-2.5 (https://www.sciencedirect.com/science/article/abs/pii/S0378778817304760) If the space is heated with a heat pump with COP of 2.5, then a HPWH with COP of 2.5 has an overall electrical COP of about 1.5, making overall solar efficiency 15-23%. Refrigerants in heat pumps are especially high carbon, accounting for around 20% of total life-cycle carbon. HPWHs have one moving part, the compressor, but HPWHs are claimed to last only 10-15 years. I have heard of a system that required two replacements in three years. PV also has failure modes. Hail damage is probably not more than for thermal, which is pretty low. Microinverters, though, are notorious for failure. A colleague has replaced about half in three different batches over ten years, and expects to have to replace the rest at some point. Unless you are using a timer to limit water heating to only when PV is producing electricity, then an apples-to-apples comparison requires batteries to offset at least part of the fossil-derived utility electricity that the HPWH uses more of than solar thermal. Batteries have high embodied carbon and don't last terribly long. HPWHs are available up to 80 gallons, so less low-carbon storage in water to last through the night.
If I were in a cooling-dominated climate, I would consider PV/HPWH/batteries because the heat that the HPWH draws from the space would usually be a benefit. On the other hand, PV efficiency decreases with ambient temperature, while solar thermal efficiency increases. It would be a hard choice that might also depend on how renewable the local grid is, i.e., if I could justify foregoing the batteries.
An important decision criterion for many these days is low life-cycle carbon. Solar efficiency, COP, upfront carbon, and replacement of parts that do not last for the life of the building are all significant factors. Trying not to generalize here, but that favors solar thermal over PV/HPWH/batteries in most US climates and utility situations.
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 01-07-2025 08:11 AM
I tend to dislike general conclusions, most given for convince and expediency reasons, understandability. Solar thermal really is a case by case decision. An example. A commercial laundromat is an excellent usage given the right site and building parameters for solar thermal. A classic case of "size (LOAD) matters". And so on and so on.... If you have advanced DYI skills, solar thermal my be the better choice. Obviously rules and regs of a given location matter as well, for both choices, along with climate. The colder the climate the more thermal gains comparatively, generally. HP efficiencies are better for cooling than heating. Geothermal changes this dynamic a bit of course.
Round and round the Merry-Go-Round goes....
Sent: 01-07-2025 06:51 AM
Very well said William, and this follows my experiences including designing two passive solar homes and some 75 PV solar systems. Thrice now I have been involved with some thermal solar for hot water. ALL three have developed leaks within 6 years or less, and two systems removed. Yet my 11.5 year solar PV keeps on producing electricity. And it is far cheaper to marry solar PV and a Heat Pump Water Heater than to use thermal solar for water heating.
David Hrivnak
SalesEngineering
Sent: 01-06-2025 11:55 PM
Despite my business is technically Solar Thermal, I have to disagree a little bit with you. PV has Lower O&M than Solar Thermal. Additionally PV is never going to leak all over your roof or floor due to plumbing failures. Both system use electricity, but only thermal (Other than solar hot air) has the liquid overhead. PV is wiring. Thermal is wiring and plumbing. Speaking of active systems here.
Second from a production measure, PV output can be easily measured and conveyed to other sources for information and systems choices in KW and KWH. Solar thermal is far more "fuzzy" in terms of end BTU's delivered calculated. Additionally you can grid tie PV. Thermal, practically speaking with the exception of district heating, you can not grid tie. This was a HUGE factor (Among many) that allowed PV to step in as the new Gorilla and replace the weak foothold thermal had in the US. There were other "business oriented" LARGE reasons as well. But, the "physical side" you can not ignore.
I like all the passive "super insulation" constructs you promote. But at a practical level BEYOND the basics, Basic air infiltration, basic better insulation, some mass consideration, is very worthwhile. Easier to expense for BTU's not lost or gained than to have the problem and try to fix it with more energy. Allot like CO2 Global heating in certain ways. Better to not put than get rid of. But unfortunately all the more advanced "constructions" are really only practical for new housing. Trying to do the more advanced constructions is highly invasive to the interior of the "lived in" house, and very expensive as retro, to name a few practical problems and wide spread demographic expertise regarding such.
Anyway, did not want to run long on this, so just a note....
Sent: 01-06-2025 12:20 PM
Thanks, Timothy, for the pictures and links about Jimmy Carter. His heart and mind were always in the right place. An inspiration to us all.
It is such a shame that our domestic solar thermal market crashed. Yes, PV produces electricity that can be used for just about anything, but solar thermal is typically higher efficiency and lower carbon. Also important is that thermal energy is easier, safer, cleaner and more reliable to store than electrical energy.
M Keith Sharp
Emeritus Professor
Louisville KY
