Thanks Keith, We are ordering a few of these devices for cell phones, and some of the stand-alone type as well to do some testing. Yah, we were very reluctant to invest in the traditional IR cameras as you mentioned, as preferred to just put that cost into commonsense weatherization instead, but with the low cost of these new upcoming devices we are excited about launching an investigation. Back in the day we would just use the human hand to feel along the walls as one can easy sense where the colder infiltrations occur. We will let you know how our experiments turn out. Thanks again for your post.
Sent: 01-21-2025 09:22 AM
Subject: Pagosa Springs Ambient House performance for 2024
Timothy,
We have to keep in mind that early IR cameras cost thousands of dollars (back when a thousand dollars was a LOT of money) and required a liquid nitrogen fill just prior to use. Today's technology is better and cheaper, and we don't have to bring a nitrogen tank along.
The phone attachments look nice, but stand-alone cameras are available that are in some cases less expensive. I see some options for less than $100. That said, I don't have experience with the new IR cameras. If anyone has recommendations, I would be interested in hearing them.
I use a non-contact IR thermometer occasionally. It simply gives a temperature reading, and provides a convenient way to check temperature variations around the interior of the house.
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 01-20-2025 01:57 PM
Keith while thinking about your post and common house insulation, and weatherization, and doing some research, got to wondering about an App or device that can detect infrared thermal imaging with a standard smart phone for detecting infrared heat escape from walls; however, to achieve this functionality seems you need to purchase a dedicated infrared thermal imaging camera attachment for your phone, which then works with a specific app like "Seek Thermal" or "FLIR One" to visualize heat patterns and identify areas of heat loss on walls. Do you use or have any other less expensive technology for average homeowners and DIYers to detect heat loss along these lines? Otherwise the commercial infrared thermal imaging devices are very pricey.
Sent: 01-18-2025 11:18 PM
Yes, it all begins with insulation. Passive House does this part really well. But it is more than that. The other things are just enough solar gain, but not too much, sufficient thermal mass, and passive cooling.
Yes, codes could make all the difference. It is encouraging that Passive House standards are being adopted in several states: (https://passivehousenetwork.org/codes/?srsltid=AfmBOooREbA5-1ZGHtYC3JeNEhXombU_xjEGmkA6bvwd0OtHu6UtqBx6) Still lots more progress to be made.
PA is pointed out as having a critical mass of Passive House professionals: (https://zeroenergyproject.com/2023/05/16/top-policies-that-propel-passive-house-in-north-america/) so there are builders in your state who do it.
Houses like this should not be thought of as only for the wealthy. Like many other energy-saving technologies, they cost more up front, but pay back in the long run. Jim Riggins did a thorough job of quantifying costs for his house (see his recent article in Solar Today). The extra cost to offset almost all space heating and cooling and water heating was only 8% of the total cost of the house. Similar numbers date back to the passive solar houses of the 70's (Balcomb reported 4-8% extra to offset a smaller fraction of space conditioning alone).
There are reasons why a modern Ambient House can be even more economical. Compared to the historic passive solar houses, such a house uses more insulation, but less concrete and fewer windows, which tend to be the expensive items. Entirely eliminating furnaces and heat pumps also saves money.
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 01-17-2025 11:56 PM
Very nice. Stable. In real-estate it is location, location, location. In housing its insulation, insulation and insulation.
It is a shame that the building codes are so far short of these parameters, because it is the codes that drives the 99% of the NEW created housing. Builders build as fast as they can as as cheap as they can. They will go as low as they can in everyway.
Until the codes require that level of insulation, only the wealthy and of those them care about environment and happen to have a builder that promotes this rather then running the other direction, the majority will remain way behind where we need to be.
Nice data set though....
