Henry,
The SunMaxx system was installed properly and the SunMaxx Bainbridge office is just down the road from the site where this system lived. SunMaxx customer service is virtually non-existent, unless you regard virtual people who have no technical information to offer customer service. They have offered zero information and have a bad rap in the solar thermal community.
Evacuated tubes have a copper rod that attaches into the heat manifold....the rods are at the center of the tube assembly and heat up and transfer that heat to the manifold where the water passing through is heated. If you take apart a tube there are the evacuated tubes, the rods, and the heat fins that attach to the rods. As I've learned, it's common for the rod-to-manifold connection to oxidize and they simply don't come out....so instead the outside assembly (tubs and fins) can slide off...but not the rod. A common problem and one of the reasons why evacuated tubes have gone out of fashion.
My primary question here is how to deal with a common problem with used evacuated tube systems. One seasoned solar thermal person told me that once an evacuated tube system goes up it doesn't come down the way it's supposed to. The system I'm looking into is only four years old. The used flat plate collectors I've used with great success are upwards to thirty years old and work like a charm.
Companies that used to sell and install evacuated tube systems no longer do so and now I know why. But, there's still potential with the system in question and I love to tinker. So anyone who's grappled with them please chime in.
Dan Antonioli
Going Green
Dryden NY
solardan26@gmail.com------------------------------
Sent: 10-18-2022 02:21 PM
Subject: Salvaging a used evacuated tube system
Dan:
If you are being offered a great deal, does that mean you are being paid to removed system?
Perhaps photos might better define "bad shape". Sometimes bad shape means it was not installed correctly, but removing glass tubes should not be too difficult. I am not sure what you mean by "rods". Do you mean a structural parts, water pipe in/out of glass tube or the heat-pipe inside the evacuated tube that transfers heat to the manifold/header? The heat-pipe type panels use some heat transfer paste that can harden, making removal difficult/tedious.
So. depending upon models/generation of panels/system answers might be a little different. Find the model number and get an installation manual on the Sunmaxx website that match. Then if you can identify questions more I might be able to help, but since the Sunmaxx has/had an address in Bainbridge, NY they too might have some answers/parts if needed.
Good luck,
Henry
Henry Vandermark
Solar Wave Energy, Inc.
Cambridge MA
hkv@solarwave.com
