Super Insulated is the very definition of something that DOES NOT get plugged in.
Enjoy your project.
Sent: 07-07-2023 10:25 AM
Subject: Solar energy -- observation from the outside
Super insulated housing. Sounds like something that has to be plugged in to be functional. I ruled that out a long time ago. In hot and humid central Texas, shading and ventilation works without a plug better than living in something built like an igloo cooler. But not many people agree with me on that either. Concept sketch attached.
Sent: 7/7/2023 12:59:00 PM
Subject: RE: Solar energy -- observation from the outside
Hi Lester: I wish you had not posted what you just did. I can not let that go.
Your very first post starting this thread, sounded like you wanted to pick a fight with Alan Greenspan rather than solve a solar engineering problem.
But to be current to this last post, the solar market is not shrinking. In fact it is almost entering into the range of exploding. Most of your financial complaints are about the workings of Capitalism, not the solar industry. If you want to pick a fight with Capitalism, be my guest, but I would start with CW (Concentrated Wealth), not an industry that is trying to ACTUALLY do the right thing for all of HUMANITY.
Almost every single one of your complaints can be found mirrored in the housing construction and real estate industry. The loan apparatus, the way they want to build the house, pre-defined designs and a resistance to flexibility. If you want something "different", be prepared to pay through the nose $$$$. No interest in people who want to paint outside the lines. Etc..
People in the Solar industry are just trying to deliver clean free energy to the planet (SO we ALL get to live) while being constantly attacked and clubbed like baby seals, by the FFI GOD level wealth machine and their bought politicians, utility monopolies only interested in RE if they get to own it, and therefore charge for the energy, on and on and on... It has been like this sense the early 70's, and I know this because I was IN IT back than with solar thermal and super insulated housing, Earth tube cooling, etc., etc..
I can easily appreciate your level of frustration, but I think there is a certain level of re-direction on your part that needs to occur.
When I see a post like that, to me it means you want to sit at the big boy table and drink 151. I hope you like 4oz Rum shots, no ice.
Sent: 07-07-2023 09:27 AM
I think my problem mostly was that I was not in the target market. Numbers really do not work without the tax credit, even with a close to median income. Even less chance with a costly battery backup. The system to maximize the sales price requires the system to be designed around canceling out the utility bill and using a maximum tax credit. My cost per month without the batteries and without the tax credit was already too high. Batteries are the first thing that have to be axed. Since the back-up is what I wanted the most, I got to feeling the only way for me to do the project was to piece it together myself. So here I am.
I have given up on finding a solar installer to consult with or to wire my system. I have an electrician who says he has some PV experience coming over this next week to see if he wants to get involved.
I am happy I am not in your business. With the interest rates going up, your small market has got to be shrinking fast.
lester germanio
Sent: 07-07-2023 08:39 AM
Hi Lester, I think I understand where you are coming from and I just want to clarify. When you say "just like you, they generally thought I didn't need the battery backup", that is not just like me. A solar PV system should meet the specific needs of each customer. I never tell anyone they "don't need" a feature. However, I feel it is my responsibility to provide insight and context around options to consider, so the customer can make an educated decision that is right for them. When I look back on this thread, it does seem like there has been a disconnect between what you are doing as plan B, and what you initially talked about with the installers who quoted you. Your plan B seems to be a smaller, 3kW to 6kW PV array, and 14.8kWh of storage, with a primary goal to be resilient and have power available that is not reliant on the grid. So if those installation companies were proposing a 14kW array and 18kWh (just a guess here) of storage for whole house backup, and the cost was $45k to $50k, and you were asking for something different, you should have insisted they listen to you and modify their proposal accordingly. If they would not oblige, then get a quote from another installer that will listen to your needs. What I and others here have been trying to do is show you how those specific needs you have can be met by installing a PV system that utilizes a hybrid inverter that can provide that battery backup power but also benefit you financially when the grid is operating fine. The problem is that you selected an incompatible inverter to do so, and you seem committed to it. I am confident that if you were to get a fair quote from and installer for a 6kWdc array with a hybrid inverter and about 15kWh of storage, it would cost significantly less than $45k to $50k, and your net long term cost would actually be much less, since when in grid-tied mode it would generate income for you. Of course, it still may be more than you can afford up-front, and that is understandable, especially when considering your point that for many Americans they cannot take advantage of the ITC because of their income bracket.
Ken Nadsady
AviSun Renewable Energy
Hudson OH
Sent: 07-05-2023 10:41 AM
Ken
The systems were the size the installers wanted to sell to me. The installed battery add-on was about $16000. Just like you, they generally thought I didn't need the battery back up since the goal of solar energy is to lower the utility bill. The size of the system I am now describing is plan B. Basically all I can afford and my only option for solar. Like me riding a bike instead of walking because I can't afford a 2023 Tesla. Sorry about that.
The reason I got the $1300. EG4 all in one is because it is 6000watt, split phase, compatible with the EG4 battery, and was specifically designed to charge and manage batteries. Two wires coming in from the combiner box. Four wires coming in from a two pole 30 amp for the built in charger. Four wires going out to a 60 amp subpanel. And two wires going out to the batteries. Probably a 1 on the 1 to 10 easy to tricky scale.
Sent: 7/5/2023 12:31:00 PM
OK. SO you already have the cheese on the side. Then you should be fine. You can parallel the two. But the connections for two separate using AC coupling is tricky because there will be no way to regulate the power from the grid tie to the batteries in a grid down scenario. When the power fails, you will have to turn off the grid tie to prevent battery overcharge. Now that said, there will be those that will tell you that you can use battery max voltage settings to hold the "overcharge" at bay. Practically speaking, is is not a good idea, especially with Lithium batteries and BLM's. That's where the combined inverter/charger/back feed has value.
The way I have mine setup is the grid tie is AC coupled to the Xantrex, but they really do not "get along" in grid out operation. SO I have my barn array feed the batteries through a 6KW charge controller and I turn off the grid tie so the whole system remains stable when the grid is down.
But you need allot of electrical design knowledge to get that whole thing right, along with the practical skills of installation. Additionally, you had better ask your utility if they require certified installers or can you use outside certification (Inspectors) to pass their requirements. If the utility requires certified solar installers, you are screwed from any grid tie aspect.
Sent: 07-05-2023 09:09 AM
I actually have a Xantrex GT3 utility interactive inverter that I got along with the Sharp panels that I bartered for. It is a 3000watt 240v output exterior model and it had been grid tied.
Sent: 7/5/2023 11:42:00 AM
The point is the solution is exactly the same regarding either choice. Straight grid tie inverters VS hybrid inverters (Inverter/charger) are not that different in cost (Sense you said "Too much" above).
The batteries are the expensive part. If you had bought a Sol-Ark or Xantrex (Schneider Electric) hybrid inverter that would not have been a cert issue for the USA, you would have both the active back feed and battery backup as well, without utility complaint. It is not some Binary forced choice. It would be like ordering a burger, fries and a Coke but saying I don't want the fries, when basically you already paid for them. The Batteries are the fries but you should have gotten the burger with cheese.
Sent: 07-05-2023 08:19 AM
The estimates i got were in the $45,000 to $50,000. range for a grid connected with battery backup system. Even with a $2500. rebate, I can't do that.
I completely understand where all of you are coming from. And how all of you are coming up with the same solution. Lets say there is a chance that the context changes. Your solution is based on saving money on the utility bill. What happens if a proxy war participant pops an EMP over each coast and knocks out the grid? Or something simple and a much more likely economic collapse happens and the grid folks opt not to supply their stuff without compensation?
So what is your recommended solution for the nutjob client that just wants an affordable just in case off grid battery backup system to provide some minimal amount of power over the long term in the context that the grid and utility bills are no longer in the equation?
lester germanio
Sent: 07-04-2023 11:44 AM
Lester, is this a roof-mounted PV array, or ground mount? And where specifically will the inverter be installed, inside the home?
Also, are you in Austin Energy territory? If so, they have a $2500 rebate for residential solar. But, the system must be grid connected, so that inverter cannot be used. You can buy a Schneider XW Pro for about $3,000, which is a much better inverter and is UL Listed and IEEE compliant for US grid. The EG4 website says that their ESS (batteries) may be compatible with the Schneider Xanbus protocol. You would need a charge controller as well to charge the batteries from the PV array, as the inverter can only charge batteriess from grid or generate AC from the batteries. Also recommended is the Power Dist Panel (PDP) from Schneider, s couple of ckt breakers you will need, and also their MPPT DisconnectRS rapid shutdown controller/switch. Yes you will spend more money up front, but you will get $2500 rebate, and you will get INCOME from the system when the sun is out.
The average US home uses 10,600 kWh of energy anually, which works oout to an average of about 1.2kW constantly all day all year. If you home is close to that average, you will at times use much more than that and at times use lesss htan that. When the sun is out and your home is only using 400W, then you will have kWh produced just wasted, assuming your batteries are full. Why not get paid for it?
-Ken
Ken Nadsady
Hudson OH
Sent: 07-03-2023 07:41 PM
program 09 -- Grd -- solar energy feed to grid configuration -- feed to grid disable (default setting) -- Solar energy back feed to grid disable. THIS (ENABLE) SETTING IS NOT CERTIFIED FOR THE UNITED STATES.
Seems like I would need to change a default setting to back feed. I will make sure and check that setting when I am up and running. I do not want to back feed to the grid. I only want to have a minimal back up battery system with PV. I like the fact that it has a built in charger and I want to use it with the feed back disabled. I currently only have 3000 watts of PV. Probably not enough to sell any back to the utility. Built in charger may get used on regular basis.
Utility does allow net metering and credits at about 9 cents per kwh. Not too bad since my average charge is about 12 cents per kwh.
lester germanio
Sent: 07-03-2023 05:59 PM
Hi Again: This thread is getting obfuscatingly fuzzy.
First if I may, I want to shed all the financial "stuff" and focus on the engineering and what the utility will allow.
Questions:
- Does your utility have net metering?
- If not, do they prohibit back feeding of electricity, paid or unpaid?
- If they prohibit any production to the grid, then and only then does you current "track" make engineering since.
- If they allow production to the grid, grid tie at a low level makes sense to reduce your grid load even without net-metering. The trick is to size the grid-tie array to only produce as little production to them as possible, yet kill a majority of your load.
- The reason I am asking this is I detected in your response about preventing back feed to be rather explicit, as if to not break rules...???....
- I didn't look to see if your inverter has what I would call IEEE normal instantaneous disconnect. THAT IS A MUST from an engineering perspective. Having both your inverter active and the grid active at the same time, or yours active and connected to a down grid is a SHOW STOPPER!!. Now I am guessing that with the international cert for grid connect, it will not have a head on collision with any grid, but you need to specifically check that spec, and get your utilities approval, assuming they allow grid connect in the first place.
I would seriously try to keep the engineering decisions separate from money issues. It will not help the clarity of the end result if you don't.
Sent: 07-03-2023 04:49 PM
Ken
We have a unique situation. We don't have a mortgage and we defer our property taxes. My wife buys the groceries and all I get to pay for is utilities and DIY projects. Saving money on my utility bill has never been a criteria for me on the system. My goal is to have some battery backup power when grid power is not available whether that is a week or years. I accept that I can't match what I have been accustomed to. This last winter when we lost electricity and water for a week reinforced that. We had several days where the inside temperature was in the low 40's at night. Almost cold enough to not have everything in the refrigerator and freezer go bad. I also bought a 48v battery charger that will charge the batteries from a dual fuel generator. The initial PV will be a little over 3000 watts. I believe this inverter has the capacity for double the PV panels and double the batteries. I am about to buy a Green Mountain 60 wood stove for backup heat. Gutters are up and we are harvesting rain.
This doesn't take away from the initial post. Seems like the marketing for solar energy is sold pushing the idea of the common good of renewable energy. But it seems that the folks who benefit the most are the money lenders. When the fact is the homeowners who need it the most can't take the tax credit and in most cases can't finance the retail install. That is over fifty percent of the American people who don't pat income taxes. Those who can pay cash are up against the inflated install prices based on the time value of money theory. Similar to housing, transportation, education, etc. and etc.
Sent: 7/3/2023 6:45:00 PM
Lester, I know you have had trouble getting guidance on how to achieve your goals for affordable solar, but please understand, the way you are approaching this is not the best way and in fact may doo you to failure. The steps for going solar are first to decide in you needs. Then start putting a design on paper, looking at available components, prices, and adjusting your design and refining it to fit your budget and your needs, and capturing requirements of the utility, the NEC, etc. Then ask for advice or do additionalt research to verify your design is solid. Then after all those steps, is the proper time to start buying equipment.
That inverter you bought cannot be used in a hybrid or grid-tied system. Utilities will not let you connect an inverter that is not IEEE1547 compliant and UL 1741 Listed. So you will not be able to build a system with it that will help save you money on your electric bill. You can use it to build a completely off-grid system, but it will be separate from the grid, i.e. you will be on grid with no solar until grid power is down, then you can switch over to your off-grid system via a transfer swith or some other mechanism. The result is you will spend a lot of money for one week of having power when the grid goes down. There are lots of other requirements like rapid shutdown, arc-fault detection, etc that you will need to consider as well when selecting components.
From what you have said previously what you really need is a hybrid system, that is grid-tied and saving you money all year by reducing your utility usage, and that can switch to grid-forming operation on loss of grid. If I were you I would try and return that inverter.
This is another reason why solar installation companies do not want to work with DIYers, because they often want to buy components and then ask to fit them into a solution. It just does not work.
I highly recommend you pause, don't buy anything futher, look into what can be returned, and follow the steps I gave above to get a solid approach and detailed design before you proceed.
Ken Nadsady
Hudson OH
Sent: 07-03-2023 01:30 PM
I had not seen the back feed capability. I need to figure out how not to let that happen.
I have a 48v EMP shield. It is supposed to be good for lighting also. I don't know how or where to install it yet. I am guessing somewhere between the combiner box and the inverter.
Do you know anything about grounding to a steel frame building? Steel roof to steel purlins to steel beams and columns to rebar in the slab; all grounded at the main service 50 feet away. I am thinking I want to research grounding the pv panels/inverter/output subpanel additionally to the steel frame close to the installation.
I believe one of the biggest challenges will be for grid water and grid wastewater when the rest of the grid goes down. Especially slab on grade houses on small lots in dense urban areas. I have been thinking about what to do about the wastewater part for a while now.
Sent: 7/3/2023 3:00:00 PM
Hello again...happy 4th BTW.
The inverter you have CAN back feed to the grid at the 240VAC and 60HZ of USA electricity. They for one reason or another did not get it certified for the USA. They call it internationally certified. AN interesting distinction, implying it can handle USA elect but did not get it specifically USA certified by USA certifing entities. A bureaucratic limitation, not engineering.
SO if you cleared it with your utility, you could back feed excess for net-metering.
Nice inverter BTW. Check bottom of page 25 last picture for back feed diagram user manual. Attached screen shot.
I like the standard rack mount on the batteries, 15KWH's is nice for short'ish outs, depending on your exact location and season of the year. Take note that lightning is NOT COVERED in their warranty!! You will want surge protectors on all inputs and outputs of that system. Excellent close grounding is imperative!!
Sent: 07-03-2023 11:14 AM
EG4 6000EX 48HV off grid split all in one inverter and 3 - EG4 LL 48v batteries
lester germanio
Sent: 07-03-2023 10:43 AM
Logical steps. If you don't mind too much, can you provide the exact inverter (Mfg., Model, etc.) that you have in your possession?
Sent: 07-03-2023 04:50 AM
Thank you for the link.
We are on the grid and currently grid dependent. I want to have an off the grid battery backup system for when the grid goes down. The inverter I bought does have a built in charger to top off the batteries from the grid but there will be no energy going back to the grid. We had a week of no electric and no water this past winter.
So, the current projects either in progress or in the planning stage:
Off grid solar with battery backup.
Wood stove.
Rainwater harvesting.
Water reuse.
lester germanio
Sent: 07-02-2023 10:15 PM
I am late to the party commenting on this. Just as a clarification, are you totally off grid doing the system or are you grid tie and wanting to make your "place" off grid capable?
A great site that's been around forever is:
https://www.builditsolar.com/
especially if you are doing it yourself.
Not knowing at this moment your answer to the above, if you are totally off grid, you tend to be viewed a step down. There are many reasons for this, some of them inherent in that functionality, some political and some Capitalistic.
I hope that site can help you from the technical side....
