Discovered a trick for cooling with nighttime air thought you all might be interested in. Nighttime ventilation cooling is driven by wind and/or by the stack effect (hot air indoors rising to exit high windows and being replaced by cool outdoor air entering through low windows). We typically don't have much wind at night, so the stack effect is what we mostly use. We have high windows in a loft, and windows on both the main floor and in the basement.
Opening the loft windows and the basement windows cools the basement well, but does not cool the bedroom on the main floor as much. We have found that it is better to leave the basement windows closed, and open the loft windows and the main floor windows, including the bedroom. Even though the stack height is roughly half as much, we get better cooling of the important rooms.
The coolest air is drawn into the rooms with the highest priority for cooling. Duh. Makes sense after the trials, but was not so obvious beforehand.
M Keith Sharp
Emeritus Professor
Louisville KY
