Hi:
My May export for the May billing period (24th to the 24th) was 779KWH's, which is pretty high. Not sure if its the highest ever because in the days before EV's, I used to get $400 and $500 dollar checks from PPL.
I am still testing my barn array (East/West) on the ground (Messy) and I just upped the string from 8 to 9. Tomorrow I will put the other 9 down in parallel (5800watts) and see if the charge controller can handle at its maximum DC rating 4800watts. The voltage under MPPT hits around 490-500VDC. Max MPPT voltage is 510VDC, so I am just under the wire. It will still run from 510-550VDC but not under MPPT. OCV is about 560-570'ish. Max feed voltage is 600VDC. I may have to put some Zenier diodes across, rated at about 560VDC, just to beginning to "clip off" if it heads for 600VDC on cloud edges if on "standby" no load, or off grid with full batteries.
My arrays are 11.77 tracking and what was on the ground for May, 2.6KW flat.
I love problems that are related to too much SUN...LOL...
Sent: 06-03-2023 12:05 PM
Subject: Unbelievable sunshine string in May!
I had similar results for May, best May ever for PV here in NE Ohio. Not as good as yours Bill but I have some shading issues and (I believe) less capacity at 16.5kw. Total net export for May was 891 kwh
Mike Curran
Retired EE
