Well, depending on the size of the array, make sure the grocery store has 3-phase on there transformer pole. When arrays start to get way above 25KW, they like to switch to 3 phase usually. If it is not already on the pole, cost will be much higher. If the store already has commercial service, mush less change will be needed there....
I would think the cost might be a bit less, since you can work off clean, supportive asphalt rather than a dirt field.
