Dear Ella (and thanks Luther) – I have not made a motorized tracker, but I have learned from solar water pump experience that the PV-motor solution is delightfully simple. Classic (brush-type) DC motors work fine powered PV-direct. No controller necessary, just two wires. Your only "control" is the shades you place around the PV to make your structure orient to the sun. You can find little DC motors on eBay or other surplus sources. Any brush-type motor will run at any voltage less than its rating, at a proportionally lower speed. And you don't need much speed. Just avoid over-power or over-speed. And that is very easy.
Example: A "12V" rated PV module will put out 15-17V when a battery or controller is not in the circuit. So use a 24V motor. Or, a 6V module with a 12V motor, same idea. This method has worked for thousands of commercially produced solar water pumps. If motion is blocked and the motor can't turn, the worst that happens is that the motor gets warm. There is not enough power there to overheat the motor (or even to blow a fuse).
I hope this is empowering!
Windy Dankoff
Author, Solar Water Pumping Specialist
Sent: 09-19-2023 09:30 AM
Subject: Solar Oven Sun Tracker Question
I'm aware of at least one dual-axis tracker, i.e., he set up a platform with two gears run by mini-solar-panels (recycled from toys, solar lights etc.), to tilt a cooker to face the sun and turn wheels to follow it through the day. Stan Wells is the designer, I interviewed him in my first solar cooking video road trip: https://youtu.be/sDpc3HRVtn0 You can find a lot of his work on and contact him through his Facebook page - https://www.facebook.com/stan.wells.526
Luther Krueger
Curator Maximo
Big Blue Sun Museum of Solar Cooking, Minneapolis
Minneapolis MN
[EmailAddress]
