Yes it is, and heat is great! But you can not charge you cell phone with it, run a well pump or charge your EV. Electricity has a way higher energy use function than low level heat. AS a person who attempted to start a Solar thermal distribution business with evacuated tubes right out of China, I appreciate Solar Thermal Engineering.
But it is the use case of electricity and the non invasiveness (PV install Not Effecting living, work space) of PV installation that wins the day, along with low loss of energy over distribution distance.
New construction is the ideal "time" for "Super Insulation" to use a broad term. And those who can afford to build new I highly recommend it. It generates a so much more comfortable living space and really low heating and cooling costs. You just have to talk the contractor out of using the worthless base energy codes.
But again as is usually the case with RE, there is no singular Golden Chalice. It's a need all of the above solution.
Sent: 06-25-2024 09:42 PM
Subject: Solar Today Article: Demand and Opportunity Today for Residential Energy Storage
Adobe is prettier than batteries, too! Even concrete, the black sheep of the thermal storage family, has lower environmental impacts per unit of stored energy than batteries.
M Keith Sharp
Emeritus Professor
Louisville KY
Sent: 06-21-2024 11:06 AM
I store my energy in Adobes. Just dirt, totally recyclable. The by products show every day. Happy Solstice!
Sent: 6/19/2024 12:30:00 PM
Subject: RE: Solar Today Article: Demand and Opportunity Today for Residential Energy Storage
I agree that lead acid is still a viable option for home energy storage. Why?
- Mature technology. We know what to expect.
- Less expensive than other technologies
- Long service life. My first set of Rolls flooded lead acid batteries lasted 17 years. Second set likely will last even longer.
- Near 100% recycleable.
- Save the lithium for mobile applications where mass and energy density matter greatly.
Tracy Dahl
Retired
Sent: 06-18-2024 10:41 AM
I was a bit disappointed in the article that under battery chemistry and safety, Lead acid were excluded, even though lead acid is still the most economical, especially where only backup power is desired and the batteries spend most of the time floating.
My Rolls special lead-acid gel batteries should last 20+ years in mostly a float state and minimal DOD. They were way less than half of any Lithium solution, and no memory effect at all.
I have nothing against Li batteries, just could not afford them.
